AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Comcast DVR 3-Device and Panasonic Home Theater
post #1 of 5
My Comcast DVR 3-Device remote control only controls the on/off function of my Panasonic home theater. I am using code 1907. Is there a better code to use? I would like to control the home theater volume with the remote. Any help is greatly appreciated.
post #2 of 5
Did you unlock the volume keys for AUX (or what ever device the home theater is set to)?
post #3 of 5
Sounds like what I need to do but I'm unsure of how to do it...
post #4 of 5
Thanks for the suggestion, I found instructions to unlock the volume..
post #5 of 5
If the TV button is flashing when you press volume buttons while in AUX mode or CBL mode that means the the remote is set to send volume control command of the TV no matter what mode you are in. To unlock it for one device (I'm assuming you have the HT device on AUX button), here's the instruction from the manual.
Unlocking Volume Control For A Single Device (Individual Volume Unlock):
1. Press AUX
2. Press and hold Setup until the selected mode key blinks twice, then release Setup.
3. Enter 9 - 9 - 3 and then press VOL- once.
The mode key will blink four times confirming unlock.
Now, when you press vol keys in AUX, AUX button should light up.
By the way, if you want to use other keys besides volume and power, other device codes might be better, depending on which model of HT you have, so what is the model number?
[EDIT] I see you already found the instructions while I was typing. I hope that worked
  Back to Forum: Remote Control Area
