AVS › AVS Forum › Display Devices › 2.35:1 Constant Image Height Chat › deos the vplvw50 have enough throw distance for my room?
post #1 of 3
Hey im just wondering if the VPL-VW50 will be able to throw the 2:35 with the Isco II from 17-18 feet away, also how high is the max i can mount it up? will 9 feet work? 1 foot above screen possibly?
thanks
Derek
post #2 of 3
A Pearl will work excellent for the throw distance (max screen size before pincushion would be ~130-135" wide x 52-53" tall) .. it does not, however, have the vertical offset. I beleive it can only be placed at the edge of the screen, not outside of it vertically.
post #3 of 3
ok so i have to make sure its exactly 8 feet off the ground then, and sitting at the end of the screen, that shouldnt be a problem. hey Jim.. whats up ?
