I just had a couple of questions I was wondering about the PS3 controllers.
1. If the USB cable is attached to the controller, is the controller still functioning with the Playstation 3 wirelessly? Someone at Target told me the USB cable just charges the battery and the controller is always communicating wirelessly.
2. Once the batteries on the PS3 controllers die can the controller still be used with the usb cable?
Thank You
Thank You
