AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › PlayStation Area › Whats a good Hard Drive to upgrade my ps3?
post #1 of 13
I want to buy one today to upgrade by the weekend. Just wondering if you guys can point me to a good 120gb hard drive that you have used with no problem.
post #2 of 13
Sorry I got no answer for you, but do you know if there is a guide somewhere in how to do this? if such a guide exist i think it should be an sticky.
post #3 of 13
A few pointers:
Get a 5400 RPM drive. 7200 has been tested to give you no performance improvement and generates a lot more heat.
Cache size shows some performance improvement, so try to get a drive with 8mb cache (a lot of 2.5" drives have 2mb)
Also, the momentus series of drives have shown to be the best quality / performance for the buck.
Finally, check out the warranty. Many of these come with a 1 to 2 yr warranty. The higher quality drives will have a 3 to 5 yr warranty. Warranty means if the drive goes bad you get a replacment... This has happened to me with my laptop in the 3-5 yr range and it sure comes in handy.
post #4 of 13
Why 120?
I wanna upgrade my HD but I'm looking at 500GB unless something bigger is cheap when I'm ready.
-B
post #5 of 13
thanks but can someone give me some examples of ones they got for their ps3
post #6 of 13
Originally Posted by Brian Hampton View Post
Why 120?
-B
The PS3 has a 2.5" (laptop-size) SATA drive. Since 160gb is the largest 2.5" drive at the moment, to use anything larger would require housing the drive outside the PS3.
I think most people are opting for the 120gb since they run about $90-100 and are widely available. The jump to 160gb adds another ~$50, which really doesn't seem worth it.
post #7 of 13
Drive at newegg.com
Looks like $115 shipped from newegg.
post #8 of 13
I bought a Toshiba 2.5" SATA 5400 rpm 120gb hdd. it had 8mb cache as well, all for $89 from newegg.
post #9 of 13
I picked up a 160gb, 5400 RPM, 8mb 2.5" SATA HDD from memorylabs.com for $130 before shipping.
Since you are not in CA, the total price will be cheaper for you because you won't pay sales tax.
Turning the 20gb PS3 into one with a 160gb internal HDD and a 160gb external HDD (Western Digitial My Book) was fun!
post #10 of 13
If you don't mind an external drive enclosure here are two links that have potential to give you a MASSIVE amount of external storage. Heck I would settle for a nice 500GB PS3.
http://www.myspace.com/playstaion3hddmod
http://www.team-xecuter.com/forums/s...ad.php?t=43957
post #11 of 13
so i have to make sure the drive is SATA correct?
post #12 of 13
The 'Safety and Support' manual packed with the PS3 has complete instructions - see pg. 16 'Remove/replacing the hard disk'. And yes, it has to be a 2.5 inch Serial ATA drive.
post #13 of 13
If you backup on an external hard drive can you load the game data from the drive, without having it on the internal hard drive? I have the 160 gb Western Digital My Book and so far so good.
  Back to Forum: PlayStation Area
