Multichannel ability?
post #1 of 7
My cd collection is now growing larger and I am thinking about organizing it with a media server. Quite a few of my cds are actually SACDs and before I seriously consider this move I would like to know whether I will be able to rip my SACDs so that multichannel is still available to be played from the media server. I apologize if this quesition is noobish, but I am not that well versed in these kind of issues. I have the NAD Masters Series Pre/Pro Amp and 7.1 channel Amp with analog input, so if the media server can serve it out in multichannel I have the means to play it.
Thanks in advance.
post #2 of 7
I don't know any single networked media adapter which has 6 analog outputs. Even Kaleidescape does not support that.
On other side how are you going to rip SACDs? I never heard about ability to rip SACDs, or DVD-Audios for that matter. You might be able to rip stereo portion of them, but, then again, you don't need multichannel outputs.
post #3 of 7
you can rip dvd-audios but not currently sacds. SACDs have a physical watermark.
post #4 of 7
thank you for the responses. I was first trying to find out whether there was a media server that "served" out multichannel audio via analog connections. If there was, I was then going to ask if there was a way to rip multichannel SACD. I can see that the answer to both questions is basically no.
Thanks for the replies.
post #5 of 7
Norgoth, many media servers will serve out multichannel audio as AC3 files or DTS wav files. They will not, however, serve out MPLS encoded files in high definition (24 bit).
post #6 of 7
Just for the record, the Ziova/Zensonic Z500 HD media player does have 5.1 analog outputs (6 connections). I'm uncertain of anything beyond that.
post #7 of 7
Just for the record, it does not play SACD nor DVD-Audio: manual. p.20.
