First, thanks to all who gave me their opinion on which sub+amp I should be looking into. But this forum is not in regards to best driver or amp - but instead in regards to its constuction.
I've been looking through multiple forums and I have seen how people have approached things differently while constructing their Sonos.
I wanted to know if the brotherhood had come to consensus on few things regarding the construction of the sub itself.
Is it better to use liquid nail to attach end caps to the Sonos? Is epoxy better? Or should one use nothing at all. How many layers of MDF is sufficient, their thickness? Is it better to use PVC pipes or a Sono while constructing the port?
What is the best way to install the terminal? Which terminal configuration works best on on Sonosubs? Link? What is the minimum gauge for internal wiring? What wires would you recommend? Internal damping material? Which one is the best or what has proved to be good damping material?
In other words, how an ideal Sonosub would be constructed. Once again, I am hoping the brotherhood of the sono's would chime in and give their opinion.
Is "Lord of the Bass: The Two Towers" (work in progress by ssabripo) one of best routes?
Would: Steve Callas, WillD, Excore, Parboy, Eric, and others would do things differently?
If anyone can share what they would have done differently while constructing their Sonosub, that would really help. On the otherhand, If you think your construction is flawless, please also share.
