I was going to put this question in the 970HD master thread, but thought it might get buried. I'd like to get the final answers about what the 970HD is doing wrt colorspace transformations when upconverting via HDMI or component (when using the hacked firmware), as a function of the colorspace menu selection (auto, rgb or YCbCr 4:4:4). The manual is clear that this option affects only HDMI output, but I wonder if that is stated because that's the only upconverting output officially supported by Oppo.
I asked Oppo what is output via component and here is the answer: YCbCr 4:4:4 Rec 601. This answer though was based on 480p output via component. It Rec 601 still used when outputing 1080i?
I wish this was Rec 709. then this would be nearly the perfect player. My display when input a 1080i scan rate uses the 709 color matrix, so I'm back to a mismatch just like with my zenith 318.
Can someone confirm, definitively, that with HDMI outputing 720p/1080i you get Rec 709 output? Does it depend on the colorspace setting?
Best,
jeff
Best,
jeff
just DVE
