After a year of me dropping hints, my wife finally said I could put a "theater" in the basement, but the catch is that I was only given about 6 months to finish it (my wife wants it done before my sister's wedding in April), my wife is an accountant, so she's really busy this time of year so I'll have lots of free time at night and on the weekends for the next few months. I'll try to post pictures as I go along, but sometimes I forget to take pictures even though the camera is right next to me.
Before the pictures, I have a few questions.
Here is the builders suggested floorplan (we are the second owner of the house, but found these blueprints in the basement after we moved in):
http://www.thelawsons.net/basement/floorplan.jpg
The problem I'm having is that the builder put vents where all the doorways are supposed to be! I built soffits out of 2x2s and pushed them as high as I could go, but I'm still not at 82.5" to fit a standard door (I'm around 81.75").
The WAF would go way up if I could fit 2-3" molding around the door as well, so that means that I'd have to drop the door height to around 76" instead of the standard 80", is it possible to buy doors this size? My local HD and Menards only have 80" doors in stock.
Next question...I hired a contractor to run the plumbing, so he pulled that permit, I ran the electrical and got a permit for that, both passed inspection so I asked to have a framing inspection. The building safety dept. said that I had to have a mechanical inspection first, but I didn't have a mechanical permit. So I had to get one. I got the mechanical permit, but I'm clueless on what I need to do. The builder of the house ran hot air vents to all rooms in the basement already, but the house was sold with an unfinished basement, so it was never inspected. Are they just going to double check the builder's work? Or is there more that they'll inspect?
I'm hoping to run low-voltage wiring soon, but I wanted to put as much as possible in conduit, but the ceiling rafters run perpendicular to the direction the wires will go (and I won't have any soffits). So I need something flexible to snake the wires in. I've seen the resi-gard stuff at HD and also the smurf tube, but both only go up to 3/4". How big of a tube will I need to fit an HDMI cable from monoprice and a vga cable? I'm thinking 1.5", but the only thing I could find locally that big was some black tubing used to drain a sump pump. It was really cheap, only $8 for 25', but I wasn't sure if code would allow me to run that through the walls. Does anyone have an HDMI cable and/or a vga cable from monoprice and willing to measure the size of the connector?
Another picture of soffit
Woohoo, new tub is installed!
Future bedroom
Bedroom closet and door
Edit: I hate it as much as the next guy when people have broken links, so I just went back through and updated all my links so pictures should show up now.
Future bedroom
As far as conduit, check out the orange, flexible stuff at Smarthome.com. It comes in 2" diameter. I ran 2 of them to the projector which gives about the same internal area as one 3" PVC pipe.
