AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › What's the right network media player for me?
post #1 of 7
After reaching a compromise solution on a need to stream content to my A/V setup around 6 months ago......
Laptop with s-video out, RF modulated via old s-video VCR, pushed through redundant RG-6 cable from old A/B analog cable TV installation, brought back to composite via RF input on DVD recorder
......I'm going to try and find the right solution in a network media player again.
Needs:
Wirelessly transmit streamed content from a subscription service that (definitely) uses WM DRM 9 and possibly (by now) WM DRM 10. Streams are .asx format and encoded with a VBR at under 350k per.
Do the same with content recorded from these streams into .asf format on the PC using Appilan's Windows Media Recorder.
Highly desireable:
That the technology be ready for prime time - reasonable picture and sound, few technical gremlins.
Somewhat desireable:
Built in DVD player which can be made region free (and possibly Macrovision free too).
Leanings so far:
Zensonic Z500.
Comments? Other possibilities?
MJW
post #2 of 7
Well you guys were no help!
Just took delivery of a Z500. I like the unit quite a bit, but it doesn't do DRM protected content at all, and some of my other video was hit or miss as to wether it would play as well.
I can get around DRM by stripping it out using Tunebite, but that's an awful lot of extra real time processing on top of making the recordings in the first place.
I really don't care wether or not my recordings have DRM, I usually watch them one time and delete them. But I DO care about being able to easily watch them on whatever device I want!
So I'm probably going to send the Z back and instead try a Helios X3000.
post #3 of 7
It's not quite the same product, but the Helios X5000 was reviewed at Secrets. It did not fare well as a DVD player, but did better as a media center. The reviewer explicitly compares it to the Z500.
post #4 of 7
The Z500 has been around here in Oz for about a year, the product is so bad they are even going to change the name of it shortly. They have a Z500 forum http://www.z500series.com/forum/ and its rumored somebody edits the bad posts out.
post #5 of 7
I don't dislike the unit at all. In fact it's been super easy to set up and it seems to work quite well with the one exception (my DRM issue aside) - video files are hit or miss as to wether they will play or not.
So, since this thing is going to be primarily a video player for most people, I think that's the biggest sticking point I have with it. I personally beleive that any device with this feature should be able to playback anything Windows Media Player can.
Going back to DRM, a lot of people have chided me for seeking support for it. Well, I don't normally buy or rent DRM protected content, but when I found a website offering live feeds of the major TV stations from my home country, DRM or not I just had to subscribe.
post #6 of 7
Did someone at Zensonic tell you this is the reason why they are changing their name?? If not, I suggest you don't make statements about matters you have absolutely no clue about!
post #7 of 7
I beleive it too. I have the unit for 2 months. VERY UNSTABLE....DONT PLAY 1/2 THE FILES. Search the forum under "zensonic z500"...i posted several comments. I know for sure the z forum deleted the bad comments. There are a few commetns i posted that i got deleted. This unit only looks good on paper.
