Linacoustic in DFW / Dallas?
post #1 of 13
Where did you find your Linacoustic in Dallas, and how much was a roll? Looking at the 1"
post #2 of 13
I've heard of a few places, I just haven't checked. I need to though.
1 is Pamco:
http://yellowpages.superpages.com/su...e=TX&zip=75226
The other is EO Wood
post #3 of 13
do a search on the JM website. Look under commercial products, then HVAC/plumbing insulation.
post #4 of 13
I've done that... and called some of the places listed. Some don't answer, others say... well, we can order it. I'd like to find someone that has it in stock w/ good prices
post #5 of 13
I bought Johns MAnville Insul-shield in Plano at:
Insulating Products Inc.
1111 Jupiter Road 108-D,
Plano, TX, 75074
Phone: (972) 509-0972
It was around $275 for 400 sf (4ft X 100ft roll) at 69 cents sq/ft
I used the coated black roll and it has very similar properties as the other products used in theater builds like OC703 and such.
http://www.specjm.com/pdf/hig1214dk....5a34d16c42496c
The warehouse manager was also a HT buff and we talked a while about what I was using it for. He was familiar with the AVS HT forum.
He had it in stock. Let me know if you find it.
Good Luck,
Mike B.
post #6 of 13
Plano, TX, 75074
Good Luck,
Mike B.
Thanks.... nice guy, but not much inventory and expensive. I think I'm going to go with the Certainteed ToughGard 2 instead. Very close to same specs (actually a bit more absorbtion at 120/250), and $170 for the 4x100 roll from SPI.
post #7 of 13
We've been getting the Linacoustic RC for $125 a roll. 1 inch 4x100 ft. They keep it stock as it must be spec'd for a lot of the office spaces in this area.
post #8 of 13
I just bought 2 rolls of Linacoustic RC earlier this week at
J-Mil Sheet Metal Fabricators
2143 Gus Thomasson
Mesquite, TX
972-681-9600
I paid $170/roll + tax
Although he called it Permacote, it says Linacoustic RC on the wrapping. It's 1" thick, 48" wide, and 100' long.
post #9 of 13
I have 2 large AC ducts running the length of my future HT. I was going to case them in with drywall. Could Linacoustic rigid board be used instead of drywall? Or should I just use the Linacoustic roll on the ductwork and then drywall them?
post #10 of 13
Has anyone else been able to find Linacoustic RC or similar locally? J-Mil wants $250 for the roll.
Tried the JM website and half the numbers are disconnected!
Tommy
post #11 of 13
Can you PM me the name and address of your seller? I would like to get one roll of Linacoustic RC.
post #12 of 13
http://www.mccormickinsulation.com/
At their Manassas Va location
post #13 of 13
Thanks!!!
