For a Dal-lite Model C high power wall installation does anyone know if the end caps for the fasteners are adjustable?
By adjustable I mean do they slide along the frame so you can fasten them to where you have a stud in the wall?
I have a wall that's about 103" wide and the screen is 99" with the frame, but the studs are 16" in and wanted to find out if this is doable. It's not recommended to install the screen to just drywall.
Thanks for the help. Can't really tell from the install instructions online from Da-lite.
