It starts with a simple example. If you take a dark gray piece of paper, and hold it up in front of white backdrop, the dark gray piece of paper looks black. Conversely, if you hold that same dark gray piece of paper up to a black backdrop, it looks much brighter by comparison.
Many of us own digital projectors that project a less than optimum black level (read: the dark gray piece of paper), and yet we choose to project this image against a black GOM screen wall (read: the black backdrop).
I've seen people mention this reality from time to time, often in the form of a question regarding its relevance or lack thereof. The most common response is that someone will mention the benefits of reducing light scatter in the room and the improvement that this can make to ANSI contrast (not on/off) and black levels. But I've never seen one single person substantiate the very real effect that the black GOM backdrop has in terms of perceived black levels.
So let me be the first.
I've had the opportunity to watch my Sony Pearl FP in action in a variety of configurations. I project onto a Carada Brilliant White screen, which I have seen mounted to a blue wall, an unfinished false wall with blue and yellow insulation behind it, and now a finished false wall with solid black GOM.
Prior to installing the GOM, I was truly delighted with my black levels. But once I covered that wall in black GOM, the charcoal grey "black level" of my projector looked more like light gray than dark gray, and certainly looked nothing like black.
The funny thing is that the contrast ratio of my projector hasn't changed. In fact, the ANSI contrast may have hedged upward by a few notches due to there being less light scatter in the room. But my blacks just don't appear as black as they did previously, and there's no getting around that.
Make no mistake, the solid black GOM wall looks fantastic when the lights are on. The screen has the illusion of floating in mid air. And when the lights are off, high APL scenes (a sporting event, for example) look even better than before the GOM went up, due to the fact that the screen almost appears to be a window in this otherwise black wall. But in low APL scenes, the lack of a true black is more apparent now than ever before because a perfect reference black is sitting right there next to it, in the form of a black GOM wall.
If I had this to do over again, I might go with a slightly more reflective color behind the screen (a gray perhaps) and make the walls darker.
Guys, you may find this hard to believe, but the presence of the perfect reference black basically makes any adjustment to the projector's black level an excercise in futility. For example, switching from high bulb mode to low bulb mode has the illusion of making the picture less bright without actually lowering the black level. As another example, turning the projector's brightness control all the way down appears to do absolutely nothing to lower the black level -- it simply crushes shadow detail and dulls the image. The same can be said of all the Pearl's fancy iris adjustments. I can see wide variances when it comes to the actual brightness of the image, but that black level just floats around at a shade of gray that is perceived as being fairly constant, no matter what I do, because of the GOM reference black. Prior to installing the GOM, all of these controls clearly had a visual impact on the black level, however slight it might have been.
In fact, I now find that I have the best image with the iris turned off. Brightness is now my best friend. A bright 3 chip DLP would look great against this wall, I'm sure. Of course, a nice CRT projector with a more ideal black level would probably look fantastic as well.
Just for reference, my ceiling is flat black, my walls are a mid-gray, my carpet is black, my seating is burgundy. The room is very dark, and the Pearl has an excellent contrast ratio and good black levels for a digital. The effect I'm seeing is clearly due to the black GOM, since it is the only element in the room that has changed.
