Originally Posted by kbarnes701
Henryld - can you just go through this with me one more time? Was everything working OK before you tried to insert the external amp? I assume you had normal sound from all your speakers?
Then, tell me that you did the following steps: you connected an RCA cable to the FL pre-out on the AVR? And repeated this for the FR channel?
You then disconnected the speaker cables from the AVR, for the FL and FR and reconnected them to the terminals on the external amp?
Then you powered up both the AVR and the external amp, selected one of your usual sources, eg DVD, and you get no sound from the FR and FL speakers?
Can you confirm each of those steps?
One more thing. Are you 100% sure that you have connected the external amp to the correct pre-outs on your AVR? I don't know your AVR but on my Onkyo, it is quite easy to connect the cables to the wrong outlets -- there are all sorts of RCA outlets on the back there that could be used (incorrectly). The pre-outs should be clearly marked as pre-outs and there will be one for each of all your channels - FR, FL, C, SL, SR, BSL, BSR, F-Height, Subwoofer 1, Subwoofer 2 etc. They are usually all grouped together in one place.
If you can confirm all that, I'm sure we can, collectively, get you up and running here.
Kind Regards,
Keith
Kind Regards,
Keith
Yes to all.
