Originally Posted by
Bill Mac
Questionable? I guess you have never used Signal Cable RCA interconnects. I have a number of their cables and they provide a very snug fit that one has to be careful when removing them. I would rather have a snug fit than a loose fit as some RCA cables seem to have.
Bill
Yes.........never used them before, I have no idea what I'm talking about. I think there is a difference between snug (secure) - and the plugs that require 2 hands to yank off - like some Monster or other so called premium cables.
Since most people know Monoprice - I'll say that their RCA plugs tend to be loose (you get what you pay for). But I've used other RCA plugs that fit so tightly you almost can't plug it in without twisting it on. If you're in the camp that likes plugs like that... then your jacks are going to face abuse.
This is a circular discussion.... as it just requires some level of common sense and judgement.
If it's such a well known problem - strange that there is little/no mention on the Emotiva forums.
