I've been considering the UMC-1 in connection with plans to modify my two-channel setup to incorporate a Geddes-style multi-sub arrangement using a miniDSP to control four subs, with EQ on the subs only. So Audyssey isn't necessary for my application as the miniDSP would do all EQ duties. Since my mains are vented boxes, I need to use a high-pass filter with them, unlike Earl's approach of running the mains wide open. He can get away with that since his speakers are of the closed-box type with high power handling. My first thought was to get a second miniDSP for the mains, figure out the required mains high-pass filter for best sub integration using the miniDSP, then design an analog high-pass filter with the same characteristics for the final solution of mains high-pass filtering. This would avoid an undesired A/D->D/A conversion, although I'd still have this conversion with the subs.
Since the Geddes approach uses considerable overlap in the frequency coverage of mains and subs, a pre/pro having independently adjustable low- and high-pass filters could make this work without any external high-pass filter. So I looked around for something in a reasonable price range that had that capability. The UMC-1 is the only reasonably priced pre/pro with independently adjustable low- and high-pass crossover filters I could find. As well, the available number of filter cutoff frequencies is matched only by the Onkyo, and even the Onkyo does not have selectable slopes for the high- and low-pass filters, nor independent adjustability of them. But reading about all the problems with the UMC-1 is scaring me away. Some people say the latest firmware is very stable and bug-free, but there are other, less charitable reports. Nobody that I'm aware of has done Markus' test or a similar one to see if the incorrect configuration of the delays in the bass management has been fixed. I've been hemming and hawing about this for a while now, but just today I read
this thread in the Emotiva forum in which two people are having a problem where the UMC-1 causes the left and right mains channels to be out of phase with each other. Whaaaat? That is very basic stuff that should never happen, especially with a unit that's gone through so many firmware revisions.
It seems to me that they are either understaffed or in need of better software people working on the pre/pros. Yet despite this, they are introducing not one, but three new pre/pros (UMC-200, XMC-1, RMC-1). The only thing I can figure out is that the profit margin might be higher for the pre/pros than the power amps, so maybe they see this as a more lucrative business area?
I think I'm just going to play it safe and stick with my Denon AVR.
Edited by rock_bottom - 9/16/12 at 2:16pm
