Originally Posted by DS-21
I assume that the Emotiva stuff is a decent commodity, and $499 is a pretty good price, though if one opens up their $499 amp I doubt it will look much different from a $350-400 receiver's amp section due to economies of scale and the like. As such, it will sound the same as other amps.
You know what happens when you assume.
Now back to the thread.
I returned my LMC-1 due to a bug when you rewind or 7 second replay.
It took almost another 7 seconds for the sound to come back,
negating the reason I went back. I think this problem was due to auto-polling which you can't turn off.
I thought I'd get use to it but couldn't.
I also briefly had the center channel bug they talk about in the avs123 forums, but it went away.
The remote sux. Select/enter is not in the circle (it's actually next to it were the "right" button is) so I was constanly going to the wrong place.
I know, use a Harmony (and I do) but I tweak my receiver and TV a bit and a universal remote is not as easy.
Some posters like the 2 channel mini-amp in it, but to me, the only sound amp in there should be for headphones, which it lacks.
The firmware was not field replaceable, so I returned before the 30 day period. I believe they have come out with a dongle so you can now update firmware at home. I wish I would have kept the amp, and reordered the pre/amp when all the bugs are gone.
