And sadly all of those issues have been solved by a simple firmware update.
Which reminds me, how easy will it be to update the new Emotivas?
It's alright Kosha, you had a good question. If the Emotiva pre/pros were out we would be able to discuss them with the Emotiva AMPs. If I am asked a question I will answer it no matter what thread I am in. That is not being a fanboy, it is being considerate of your fellow AVS member.
Which reminds me, how easy will it be to update the new Emotivas?It's alright Kosha, you had a good question. If the Emotiva pre/pros were out we would be able to discuss them with the Emotiva AMPs. If I am asked a question I will answer it no matter what thread I am in. That is not being a fanboy, it is being considerate of your fellow AVS member.
