Originally Posted by T-Bone
I take issue with "There is no reason for them to "lie" about built in surge protection, no reason at all."
Their XPA-2 specs state 120,000 uF of capacitance. Yeah, they have 12 caps, each rated at 10,000 uF. But they are not all wired in parallel (that would be required to reach 120,000 uF). They are wired in series-parallel. Effective capacitance is MUCH lower than 120,000 uF. Why would they claim a capacitance value that is not correct? It's called specmanship. They lied to sell a product.
-T
-T
http://emotiva.com/xpa2.shtm
• Secondary capacitance: 54,000uF
Where are you getting this 120,000 uF of capacitance? This Secondary Capacitance is the only thing I could find on the web page in the technical specs that references capacitance.
AFAIK, the only source of this 120,000 was from some pre-release tech specs that were incorrect and were corrected. Hardly "lying".
http://emotivalounge.proboards54.com...65&page=3#2128
"Right now there are 12) 10,000 uF caps in total. But they are wired in series pairs. Which basically means that it has 30,000uF of capacitance as it is now. I made a mistake when I wrote out the orginal spec sheet for Dann as I just took the 12 x 10,000 rating which is not correct. So even though the power supply is as solid as a rock, I still want to up the capacitance on it. That being said we will probably double what you see in the pics."
Sounds like they are being pretty honest and up front about things. 54k isn't quite double, but it's close enough for me.
