I have the Cambridge Soundworks 2.1 Digital speakers. I am planning on using a VGA cable to get my display from the 360 to my monitor, however I am not sure how to get sound.
I am getting a VGA cable and this is the description of it (can't link yet):
It has digital input, and my speakers have a digital in connector so I am assuming I will connect the optical input from the cable to the input on the speakers but I'm not sure. Can someone confirm this is correct? I also have the subwoofer on the floor (this is where the input is) and the monitor is on the desk so they are about 4' apart, but it doesn't look like the input on the cable, and the sound output are going to split that far. I'm kind of confused what to do.
# The unit can be used with TVs, PC monitors and projectors equipped with VGA input only.
# An optical input is also included, giving you the option of enjoying crisp digital sound.
