I am new here, so I apologize if this has been discussed already.
I am looking to aquire a simple digital photo frame, but the available options seem to be either way too small or way too expensive. For example, the commonly available frames are significantly under my desired minimum and the only sizable displays (the 19' frames from PhotoVu) are too expensive for what you get.
There are any number of articles about converting old laptops into frames, but this is not a path I wish to pursue. I lack a spare laptop and the desire to rip one apart, plus the screens are still too small for my taste.
So...My plan is to frame (in a shadow box of coarse) an LCD monitor. I want the unit to be self contained, so it cannot be driven from my media center PC. What a need is an inexpensive media streamer (the cheaper the better as it will only be used for photo display). What is the best option from your experiences?
It needs to have some sort of high res output (DVI would be preferable) so that eliminates many of the lower-priced SD-video streamers.
The DVico HD-5000A is out because its form would be impossible to integrate into a photo frame. The unit must be sleek enough to fit in the frame.
The Mvix MX-760 HD seems to do what I need, but it is expensive and overkill for this task. I will use it if nothing cheaper can be found.
The Avix and Modix streamers are cheaper, but they do not have any sort of computer monitor outputs.
The Kingwin KH-300 has VGA output, but I don't know how the picture would be. Does anyone know the quality of the photo output. I am guessing that it would not be high resolution (definition) even over the VGA hookup.
If anyone can think of any other alternative, or if you have experience with these devices and photo display, please let me know. All I really need is a device capable of outputting a picture over a DVI or VGA connection at a reasonable resolution, say 1024x768 or higher.
Thanks for any help!
N
N
