Originally Posted by btc9800
thanks for the suggestion.
But, yes whenever I make a cable run I always leave additional cable slack.
A good deal of the cabling seen in the photo will be eliminated shortly.
Wed of this coming week I am having a DN VIP722 HD receiver installed which has an HDMI port.That will eliminate 2 cables. Also my dvd player is presently connected via component....that will eliminate 4 cables, as it also has an HDMI port. The SD receiver I now have will be retired. It does not have HDMI only has comp, RCA, Svideo, jacks.
I also ran 2 dedicated 110 vac lines with duplex receptacles, and an RJ 11, which you can't see behind the side legs of the overmantle. I constructed the complete wall cabinetry so it can be removed for modification if ever with out injuring any it. Also should I sell my home, a prospective buyer may disapprove of it, benig it is in the living room.
Understood. Again, good thinking/planning on your part.
While you are replacing several of the cable runs with HDMI, since they are already in the run, have you given thought to:
1- leaving them their for future upgrades
2- putting in an extra HDMI or two in there now?
since it will be easier to do at this time for additional equip down the road. AND..., if needed you can always use the cable in the run as a "pull through" to draw the new cable through by taping them together.
Just another thought for future proofing to avoid "Murphy's Law"
..Mark
