AVS › AVS Forum › Display Devices › Rear Projection Units › Toshiba 56HMX96 DLP Settings
post #1 of 4
I just got a Toshiba 56hmx96. The settings from the factory seem a bit off. If anyone owns one of these DLPs can you tell me what settings you like? Also do you watch with the lamp on high or low?
post #2 of 4
Ok thanks, I'll give them a try!
post #3 of 4
Nope, it looks exactly like it did before, no change.
Any other setting?
post #4 of 4
Congrats on the new tv.
I've used Avia to set up the tv under composite and component. For composite a toshiba dvd recorder and rca dvd player were used. For component the same toshiba dvd recorder and an xbox were used.
composite: (toshiba)
contrast 79
brightness 47
col 32
tint -5
sharp 19
col temp warm
dynamic contrast low
color management (all saturation)
green 18
red -2
blue 3
composite: (rca)
contrast 79
brightness 47
col 32
tint 0
green 17
red 0
blue 3
component: (toshiba)
contrast 79
bright 74
color 34
tint 0
sharp 19
col temp warm
color management (saturation)
green 18
red 0
blue 3
component (xbox)
contrast 79
bright 74
color 33
tint +5
sharp 19
col temp warm
green 18
red -2
blue 0
All modes low power. Hopefully the lamp will last a bit longer.
For hdmi i found the composite numbers (toshiba) looked better (my dvd player doesn't have hdmi). Flesh tones look fantastic but my eyes may differ from yours. Trial and error might be your best bet until you can find a test disk.
best of luck
stephen
  Back to Forum: Rear Projection Units
