AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Software › "Uncompressed Audio" Observation/Question
post #1 of 8
Hi All,
I am new to Blu-Ray, but do have a pretty fair knowledge of modern A/V equipment. I am using a Denon 5803, which is a THX Ultra-2 7.1 amplifier, and it was their "top model" a few years ago when I put everything together. This evening, I hooked up my PS3 in our dedicated movie theater to set things up and to check out and sample a few Blu-Ray titles. Of these titles, I popped in X-men 3, Jay and Silent Bob Strike Back and The Terminator.
Each of these movies had an "uncompressed audio" selection. X-Men3 was first up, and I was very pleased to see that my receiver treated it like a DTS bitstream. The "DTS" indicator light came on, and the receiver automatically decoded the signal in the "Ultra2 Cinema" mode that it was supposed to. This is the exact same thing that happens whenever I feed it a "dolby digital plus" signal from the HD DVD source. All was well.
Now for the confusing part...
Next, I popped in "The Terminator" and noticed that it ALSO had an "uncompressed audio" track on it as well. It had defaulted to "Dolby Digital 5.1", and the receiver (again) automatically flagged it for "Ultra2 Cinema" processing. The indicator light showed that it WAS receiving "multi channel audio", and this indicator is (or course) different than the "DTS" indicator light, and is completely normal when using any traditional 5.1 source.
So, I chose "uncompressed audio" and something REALLY STRANGE happened. The receiver did NOT identify the bitstream as either traditional DD 5.1 OR DTS. In fact, the processing mode that it indicated on the receiver went to "THX HOME CINEMA", which is the normal mode that it will fall back into whenever the audio signal drops down to regular 2.0
Another wierd thing is the fact that (at least in my mind) it "sounded better" and I could distinctly tell that the surrounds were receiving different information than the center and front channels and it appeared that some positional audio effects were taking place. I then put "Jay and Silent Bob Strikes Back" in the player, and when choosing "uncompressed audio", it exhibited the same traits as "The Terminator". I am kind of at a loss as to why the X-men 3 "lossless" mode would be treated by my amplifier as a high quality DTS track, and yet the other 2 movies were not.
So, my question is this... Even though the "uncompressed audio" track on these discs is listed as a 5.1 channel source, my receiver is showing every indication that it is handling it as if it were a 2.0 signal. Has anyone else experienced this, or is this because the data transfer is not compatible with my "3 year old" receiver? If this has been covered before in the past, then I am sorry, but I am new to the "Blu-Ray" experience. Now, before anyone asks, yes I DID set the output to "bitstream" and checked all of the boxes for audio codec compatibility. Any insight that you might be able to provide on this would be greatly appreciated.
In the end, I don't know if it really is going to make that much of a difference in my overall viewing experience, but I would really like to know if the "uncompressed audio" track are supposed to be accepted by my receiver as "non multi channel", even though the menu describes them as 5.1...
Lee
post #2 of 8
For you to get the full benefits of uncompressed audio tracks, you need to let the blu-ray player do the decoding and output the audio as multi-channel PCM through HDMI connection or using multi-channel analog connection. Because PS3 doesn't have analog outs and your amplifier doesn't seem to have hdmi input, this is not possible. In the future, it will be possible to use hdmi 1.3 and let the amplifier do the decoding.
Kari
post #3 of 8
Hi Lee, the answer to your question is quite simple, but you probably won't like it. Judging from the fact that your receiver is a couple years old, you must be using the optical out of the PS3 to get the audio into your receiver.
Blu-Ray will not send the uncompressed PCM audio over the optical cable, the only way to get uncompressed audio is to have an HDMI connection to your receiver which I am guessing yours does not have. The reason you are getting a high quality DTS audio stream from X-Men 3 is because the soundtrack on that BD is encoded in DTS-MA, a lossless codec that has a lossy core which can be read by regular DTS decoders, it's probably the best audio choice the studios have for saving space and not making multiple audio tracks. So far only Fox has come out with discs that have DTS-MA though. To be clear, you are NOT hearing a lossless or uncompressed audio track on X3, just a very high quality lossy DTS track.
Most of Sony's discs have two different choices for audio. Linear PCM(Completely uncompressed audio) or DD5.1. If you try sending the LPCM track through your optical connection you'll get a weird sounding 2.0 mixdown of the 5.1, 6.1 or 7.1 mix, and your receiver will probably try to process it as Pro Logic 2 and that's why you are getting the weird positional sound in the rear speakers. Your best option in this situation is to select the DD5.1 track, and in your BD audio settings on your PS3's system menu make sure it's set to bitstream and NOT linear PCM. Unfortunately if you want to hear the uncompressed and lossless audio streams from BD or HD-DVD, you'll need an HDMI receiver.
post #4 of 8
Lee, as a former Huntsvillian, I hate to break this to you. I don't think your receiver (which I know was a flagship) supports HDMI audio. I believe HDMI 1.1 support is only in the 5805.
http://www.audioholics.com/productre...compared01.php
Uncompressed PCM and advanced audio codecs are not supported over SPDIF. The same thing goes for HD-DVD. You need to utilize players with 5.1/7.1 analog outputs to get uncompressed audio through your Denon (or upgrade to another receiver).
Sticky: 5.1/7.1 PCM, HDMI, and DSP - An Explaination of the Future-Proof receiver
post #5 of 8
Kari
for now you can decoding DolbyTrueHD in PS3, and you need to send it thru HDMI to HDMI 1.1 capable receiver.... to get sound........
PS3 will have DTS HD MASTER decoding in march with new firmware....
Marek
post #6 of 8
LeeB99 from Xmen3 you are getting only DTS core 1.5mbit from DTS HD MASTER...
so that's why you have DTS icon on receier....
no player at this momnet can decode dts hd maste...
marek
post #7 of 8
Thanks for the feedback on all of this. I was kind of figuring that since my receiver was processing it as a "2.0" source, then it must mean that it was not accepting it as a multi-channel source. I guess that I will just have to "live with" the regular 5.1 for now, and use the special Fox track when available.
I HAVE been able to listen to the "lossless" audio track on my HD DVD's, since my player has the analog outputs and does the processing "on board". I guess that this is just ANOTHER case of where a manufacturer (Denon) sells something that is supposed to be "upgradeable" and "future proof" though firmware updates, only to find that the "new" state-of-the-art standard has nothing to do with optical or coaxial connections.
I WOULD change my receiver, but I think that would be going through too much trouble. And I don't even think that my ears would perceive much difference. Personally, I can't tell any difference between the "lossless" TrueHD analog output on the HD DVD's versus the "downsampled" version that is processed in my receiver as a DTS bitstream when I select coax as the source rather than the analog inputs...
Lee
post #8 of 8
Lee,
I am almost in the exact situation as you as my Denon 5800 doesn't have any kind of HDMI input. That is why I haven't bought a blu ray player yet especially the PS3 because of no way to output the uncompressed sound to my Denon 5800. If money was no object I would buy a Panasonic or Pioneer blu ray player and use the analog outs to my 5800 but I am not spending over $500-600 on a blu ray player.
Our Denon receivers cost way too much and sound too good to be ditching them for a HDMI receiver. So, I wait........til I can get a very good blu ray player with hopefully 7.1 analog outs and a sharp picture.
Mike
  Back to Forum: Blu-ray Software
