AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › PlayStation Area › Linksys WRT54GS Wireless-G Broadband Router with SpeedBooster
post #1 of 7
WILL THIS WORK WITH THE PS3? SEEMS LIKE IT WILL WITH THE 360..I NEED A ROUTER THATS COMPATIABLE WITH BOTH, ANYONE HAVE ANY EXPERIENCE WITH THIS ROUTER...MY D-LINK DI624 ROUTER IS GOING IN THE GARBAGE..
WHAT ROUTERS ARE YOU GUYS USING?
post #2 of 7
Dude, find your caps lock key.
I have a WRT54G (the same router but without the "SpeedBooster") and it works fine with PS3.
gandalf
post #3 of 7
I'm using the same wireless router & it works fine.
Check out http://www.avsforum.com/avs-vb/showthread.php?t=754875 For a list of routers that do & don't work.
post #4 of 7
I have this exact router.... My 360 and PS3 are hard wired while the PSP and Wii are wireless. Works great. I did have to open up the NAT settings for the 360 however because of some communication problems I had over live. Hardest part of that was figuring out how to do it.
post #5 of 7
how did you open your NAT settings?
post #6 of 7
I had to assign a static IP to the 360, then open up 2 ports in the router for that address. Sometimes you also have to disable the UPnP which was in my case.
It sounds kind of complicated, but it's really not. My other devices had no issues before or after opening the NAT.
post #7 of 7
I have the WRT54G that was converted to a GS with different firmware and I have NO problems. Plug and play for me.
  Back to Forum: PlayStation Area
