AVS › AVS Forum › Blu-ray & HD DVD › HD DVD Players › HD-A2 no Audio
HD-A2 no Audio
post #1 of 5
I am having an issue with no sound, when using the optical out from the hd-a2 to my hk avr-240 . I have the optical set to pcm and the hdmi to auto. I am using the hdmi for video on my hl-s5687w samsung tv. I can never get any sound whatsoerver. However, if I plug my avr-240 optical input to the optical output of my tv I can get sound. Is this how it should be done ???? Please advise !!! Thanks
post #2 of 5
Any ideas???
post #3 of 5
Did you try "bitstream" for optical? Is the receiver set for digital on that input? Set HDMI to "PCM" if using optical.
post #4 of 5
Maybe thats my problem, you mentioned set reciever for digital on that input ? Thats what I am not sure on how to do.
post #5 of 5
Usually there are a few choices in the "setup" menu. "Digital/Analog/Auto" is common. If you haven't gone into setup, it might be set to analog by default.
  Back to Forum: HD DVD Players
