AVS › AVS Forum › Display Devices › CRT Projectors › Where would you suggest buyng a 45Ft HDMI Cable?
post #1 of 8
Hello Everyone,
This is my first post so I am sorry if this is the wrong area. I have 4 questions that I need help with, the first 2 are the most important. I just bought a Sony VPL-VW50 Projector.
My first question is: I am going to need a 40-45 ft HDMI cable to bring video to the Projector. Is there a place or website anyone would suggest to buy from that has Quality HDMI?
2nd Q: Is there quality issues with HDMI cables or is one better then the other?
3rd Q: Do you think I will lose quailty of picture of the 40 Ft distance of the HDMI Cable?
4th Q : I just ordered a Pioneer Elite VSX-84TXSi, Is this the best option for the 1,000-1500 price range? I got the amp new for 1050.00. Let me know if you think there is something way better for the money.
post #2 of 8
Hello
Some of these signals are only rated to seven feet for DVI and maybe HDMI, beyond that length a fiber optic or other amplified cable may be required.
post #3 of 8
Thanks for the help,
I dont where to find the fiber optic or amplified cable. Do they look the same is the HDMI Hookup?
post #4 of 8
This one is a slam dunk...monoprice.com is the best way to go. They fully test the cables to certain specs, so the length of cable is irrelevant. The cables are good value, secrets did a review of them.
Ben
post #5 of 8
I second Monoprice!
post #6 of 8
Third for Monoprice!
post #7 of 8
post #8 of 8
Thanks again for all the help. Well.........Monoprice has 2 different 50 ft HDMI cables 1 is a in wall cabel in copper, and the other is a normal cable in gold. The Gold cable is backordered for another week which might be a problem for my move in.
I am building a new house that will be done on the 26th of this month. In the wall I ran a plumbing PVC pipe all the way from the projector to the Amp so i can change out the tech. Do I need the inwall wire? Or is the PVC shielding enough.
Also is gold much better the copper for connection? I would really like to order the copper one so i can have opening night with my sony pearl! But on the other hand I want the best connection possible......Let me know your thoughts!
  Back to Forum: CRT Projectors
