AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › SVS /2 Questions...
SVS /2 Questions...
post #1 of 8
Man, I should have never found this forum, its going to turn out badly for my savings account... now on to the question at hand...
I was originally looking at getting an SVS PB12-plus to use in my home theater setup. The more I read, however, I'm beginning to think it will not reach to where I want to be. In my younger days when I didn't have very good common sense (yeah, I know, not much has changed!), I removed the rear seating in my Z28, and shoehorned 4 pro grade 18" subs in there with a true 1000 watt amp - I like to really feel it. The HT room I'm trying to fill is around 5500 ft^3, and I'm convinced I'll need the plus/2 to achieve the affect (or is it effect?) that I'm desiring. But then I start to wonder if perhaps I should go all out and just get the ultra/2.
I guess my question is has anyone made a close comparison between the plus/2 and the ultra/2? Is there significantly more headroom? Is the bass more musical, tighter or deeper? I probably will be using it for equal parts music and movies, if not perhaps more for music (all types, but I have an affinity for jazz, and I like good tight bass in my jazz).
Guess I'm just looking for justification for that extra $700.
TG
post #2 of 8
SVS is unveiling the new 13+" Ultra tomorrow at CES. So as they say, let's see what tomorrow brings
post #3 of 8
I'm with g. If you can be patient, see what the new Ultra is all about. From Ed Mullen's reports, a single new Ultra may get you all you want for SPL and SQ.
post #4 of 8
This is totally my opinion, so take it for what it's worth. I own a PB12-Plus/2 and my father an Ultra/2 and in terms of output there is NO difference between the two. Of course these subs are in two different houses which is a HUGE factor, but volume wise they are very similar. The Ultra/2 certainly is a little more accurate but in no way worth the $700-$800 additional price tag IMO. My Plus/2 achieves as good SPL though without question.
I think that anyone considering an Ultra/2 should likely go with two HSU VTF-3 HO's with turbos. I don't know if anyone has ever done a side by side test of an Ultra/2 verses a pair of turbo VTF-3 HO's, but the cost is EXACTLY the same for either setup and I'd put my money on the two VTF-3 HO's to dig lower and output more SPL.
post #5 of 8
You will most definitely need more than just the PB12-Plus. Slightly smaller dual subs will serve you even better than one larger one. I like the HSU suggestion given above. I'd put my money on two of them vs. a single Ultra/2.
BTW, I have dual PB12 +/2 s in 3300 cu. ft. One is sufficient. Two simply kills!
post #6 of 8
posted @ 12:21 Monday...do u mean 2sday based on your post's time?
post #7 of 8
Where does the time go?
CES is Jan 8-11. So it's all up to the folks there to report back...
post #8 of 8
Where The Hell Is Our Info Dag Nabbit !!!!
