AVS › AVS Forum › Video Components › Cable, Digital Cable - Non-HDTV › s-video to dvi?
s-video to dvi?
post #1 of 2
I got a 19" lcd monitor for christmas. It has a vga and a dvi connection, I would like to take it with me when I go to school, and have my xbox 360 using the vga connection and my ps2/original xbox using the dvi connection. is there a cable/device to convert it from s-video to dvi? or possiblty to vga then the dvi adapter.
on another subject does anybody have a tv tuner card for there pc that has no delay issues? like when you jump there isn't a second before you jump on the screen.
post #2 of 2
My video card has DVI to VGA adapter- that's easy. There are also VGA to S-video / RCA adapters, used for video card outputs. Here's an adapter: http://www.monoprice.com/products/pr...ormat=2&style=
Caveat: I don't know if the pinout for going in the "other" direction, S-Video to DVI. In other words, is it a simple wiring connection or is there something else inside?
  Back to Forum: Cable, Digital Cable - Non-HDTV
