Hi all
First I have to say that this is a great forum with heaps of amazing and interesting info available - Thanks to you all.
I have a D50 that I'm intending to replace the tubes in (fairly severe burns and lowish output) but before I do that i would like to make sure that the proj is working as it should and need to investigate the following fault.
Has anyone come across a fault where the Brightness control has absolutely no effect? Can adj from Min to Max without any noticeable effect. Have adj Sub Brt on A board also but makes no change (put it back to where it was!) ABG and ABL is OFF. Contrast adj seems normal.
Any clues would be greatly appreciated.
TIA Wild_Willy
TIA Wild_Willy
I know how you feel.
