I need help to find a good store that sells a lamp replacement of the sharp xv-z9000 (japan model). I knew that it is kindda old PJ. But i still want to use it couple years before replace a new projector.
I see some of the lamp replacement sell on ebay, but then some users list that "Beware of cheaper copy bulbs as they put a rainbow effect on your screen" . ANd some store on Frogger sell only the bulb. I want the whole housing unit (brand new factory sealed), so it easier for me to replace and less problem or none of damand to my PJ.
And advice would be appreciate. Thanks in advance.
