AVS › AVS Forum › Display Devices › CRT Projectors › NEC flapping - why is red different to blue?
post #1 of 2
Just an aside question, I was helping to setup an NEC PG+ a few weeks ago, and we had to work out what flapping rings went where as they had been pulled out.
It turns out the flapping rings on the Green and the Blue are the same (marked TB and GB), but the RED tube has a different flapping ring (marked sensibly enough R)
I would have expected the Blue and red to have the same (or mirrored anyway) rings and the green to be different.
I know you set them differently, but I was just wondering why the green and blue would have the same ring types but not the red?
post #2 of 2
Ahh don't worry I'm an idiot, I just worked it out.
  Back to Forum: CRT Projectors
