AVS › AVS Forum › Audio › Receivers, Amps, and Processors › new 3806 owner
new 3806 owner
post #1 of 2
Couple "o" questions,
Anybody else having issues upconverting video from the x-box 360 on this 3806 piece? To date the only video I can get to pass through is my ps2. After asking an install guru about my dish-network box issues It sounds like there encrypting signal
from the box so it will not pass. any ideas on this issue?
post #2 of 2
Are you having problems getting ANY video at all? What I have had problems for with my 360 before was that I saw no video when I hooked it up to a new tv using the same component plugs I had to flip a switch on the plug that goes into the 360. I believe one side says SD the other says HD (can't go look atm). Not sure if you tried this already, but that may be 1 problem, I know I almost had a heart attack when I didn't get video and thought it was damaged in shipping.
Just ignore me if you already tried this.
