AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › Urgent! Pls,help! Sony Rdr-gx7 Pal Dvd Recorder Firmware Ver.1.82
post #1 of 15
Dear All,
RE:PLS,HELP! SONY RDR-GX7 PAL DVD RECORDER FIRMWARE VER.1.82
Happy New Year !
Please, help!
I had a working Sony RDR-GX7 PAL DVD RECORDER with FIRMWARE VER.1.82 .
It was working very well, only did not accepted DVD-RW ver.1.2. ( Only older DVD-RW ver.1.1 ) .
I was given a what was supposed to be a Firmware upgrade (Ver.1.30).It is a file, which you burn on a CD and insert it into the DVD Recorder.
After I put the CD and istalled the Ver.1.30, my Sony RDR-GX7 stopped working at all: No signal to the TV; Does not even play Original PAL DVDs, etc...
Compleately dammaged and not working...
So, would you please, send me the file, containing the Firmaware for Sony RDR-GX7 Ver.1.82 or higher, so I can return to the previous firmware of my DVD recorder and make it work!
Thank you very much for your help!!!
post #2 of 15
The Sony GX7 is a pretty old model at this point in time and was only popular with just a handful of members here at AVS. I remember only one or two members in this DVD Recorder section that posted about firmware updates for that model but it's been years ago. And those few probably upgraded by now and/or don't frequent this section much anymore so I would guess that it would be unlikely that you would get a timely response, if at all.
Given that, I would post your question with Sony tech support. You will probably get a more timely response over there.
http://www.sonystyle.com/is-bin/INTE...t.isml#product
nx211
post #3 of 15
Thank You.
Sony Are Famous For Not Helping Unless You Have To Send It To Their Service Center...!?... Hope I Am Wrong..
It Will Only Take 5 Min To Update...
Please, Help!
Thank You.
post #4 of 15
Hi.
Is it possible that the file you were given was the NTSC version? If so, maybe there is a PAL version available from the same source?
post #5 of 15
I would assume that you have the NTSC version as the current PAL version is 2.3.
Undating the firmware would have only fixed problems with known bugs it would not have given any extra functionality or even allowed for revisions id DVD-RW versions.
The latest NTSC version listed is 1.3.
Are you sure you have not used firmware from another model
Revised what i was saying:
You have installed the firmware for the US/ Canada Model. What you need is 2.3 for the PAL version, reinstall the new firmware and it should spring back to life except probaly wont fix your original problem
post #6 of 15
THANK YOU TO ALL !!!
Mr_Mod,
I came to the same conclusion, which unfortunately can only be experienced after the event:
i.e. after I have changed the perfectly good working Ver.1.82 ( for UK ) to the what I understand is NTSC-Ver.1.3, being told( and thinking) that was the latest.
They forgot to mention....lates fot NTSC...
Thank you, again for everything..., but how to change it back???
I do not have the files of Ver 1.82 or Ver 2.3 .
PLEASE, SEND ME Ver. 1.82 and/even better Ver.2.3 so I can sort the problem out !
Thank you very much for your HELP !!!
post #7 of 15
AAAVIDEO
If your still having the problem read the PM i sent you. I can send you the firmware but is about a 12meg file
post #8 of 15
Sony RDR-GX7
Using the RDR-GX7 for 3 years now. Great machine until recently. I use the GX7 to record tv shows. I play the recordings on other players. (Sony,Toshiba, etc). I've had problems with newer Sony Blank +/-RW DVD discs. It will no longer recognize the +/-RW Blanks, for any Brand, or play movies of the same format that the machine itself recorded earlier. It will record to -R, but will not play -R, even after being finalized. All of these dvd's will play in my other machines. Hoping that a firmware update on this forum might help.
My Disks are the Sony Brand, and they have version DVD +RW 1.2 on them, and are 2x-4x for speed. I noticed in my manual that this machine uses version 1.1. But these Disks worked before, don't understand it. Hoping for a firmware update so I don't have to Upgrade. Can someone recomend a good progressive scan machine if that's the course I have to take? Or tell me how to get that firmware Upgrade if it can fix my problem.
Thanks, R. Kleinsak
post #9 of 15
why not read the post before the one you posted and the third one. It tells you how to obtain the firmware.
post #10 of 15
Hello
I know this thread is old but I need firmware 2.3 PAL for the Sony RDR-GX7?
If anyone got it please send it to my mail xelandros@tiscali.it , it would be appreciated.
Thank you.
post #11 of 15
How can I see what firmware is on my machine ? Has anyone have the latest PAL (Europe) firmware ?
Facing trouble with several discs that the RDR-GX7 cannot read.
post #12 of 15
nice...............................
post #13 of 15
V2.3 firmware only fixed a bug with characters when the user has set the player tom operate with spaninsh text.
There is no fix for this machine if it cannot read or write to discs that are not 1X writable.
It may be possible to exchange the drive to a more recent PC variety that is capable of doing this however i have never tried this.
post #14 of 15
Maybe someone will be so kind to send me the lastest firmware for my RDR-GX7 dvd recorder, getting more en more C1300 ( etc. ) errors on different DVD-R media.
If anyone got it please send it to my mail goofy_and_friends@yahoo.com , it would be appreciated.
post #15 of 15
Originally Posted by Mr_Mod View Post
AAAVIDEO
Please could you send me that firmware too?
rdr-gx7 Euro (IT)
  Back to Forum: DVD Recorders (Standard Def)
