I need to replace my dying CrystalImage scalar and I'm looking for a little advice on what to get.
I currently have an Electrohome 8000 CRT. My current inputs are:
- DVD player (component to the scalar)
- Motorola 6412 set top box (component to a transcoder, VGA from the transcoder to the scalar)
In the future, I'd like to have:
- HD DVD player
- Motorola 6412
- XBOX 360
Of course, budget is an issue. My local home theater company has suggested getting a Lumagen -- one of the Vision HDx line.
(Note to Lumagen, any chance you could put on your web site, in English please, what the difference is between the various Vision HDx models? I've looked at your site several times, and still haven't groked the differences, other than cost.)
The Lumagen looks like it is within my budget, but I'm a bit hesitant buying a scalar that can't do 1080p and HDMI. I realize that my CRT can't accept either, but from a future-proofing point of view, it seems to me that I'd be buying a scalar that is already obsolete.
Is there a scalar that will do 1080p and HDMI (and have RGBHV BNC outputs as well) and is also < $2000? Or am I still smoking some illicit?
Which other scalars should I be looking at?
- HD DVD player
- Motorola 6412
- XBOX 360
