While going through the DVE dvd and trying to calibrate the colors I ran into a so-far unresolved problem. After adjusting the color and tint (I thought tint should have been disabled using HDMI, go figure) using the blue filter, I can get the blue "squares" almost perfectly in sync with the filterbut the cyan and magenta "squares" are still off a bit. Also, while viewing through the red filter on the same pattern everything is quite closebut viewing through the green filter everything seems way off.
So, the question now becomeswhat to do?
I'll update with my settings later tonight.
Any and all help would be appreciated.
