AVS › AVS Forum › Home Entertainment & Theater Builder › Game Room Equipment & Accessories › ? Pool table in 13'6" long room?
post #1 of 8
Is there any pool table/que combo that will work in a 13.5 foot long space length wise.
Width is not a problem as one side is open but I cannot orientate the table in that direction.
thanks
post #2 of 8
go here http://www.ornerbilliards.com/ and check out the dimension chart.
post #3 of 8
you could get a bar table. most of those are about 7' long. According to the previous posters website, they recommend 5' on all sides. What I would do is marki out a 7' table w/ masking tape and then get a cue or something that you could manipulate to the different size cues and see how that feels.
You may just have to use a shorter cue.
I found this if you are interested.
http://www6.mailordercentral.com/bum....asp?dept=1035
post #4 of 8
I just had a pool table installed and 60" is the bare minimum distance on all sides in order to use a full length stick. One small portion of my table doesn't have a full 60" clearance so I just bought a shorty stick for those situations.
post #5 of 8
I had a friend try and put a bar table in a similarly sized room... 3 or 4 cue sized holes in the sheetrock later he decided it was a bad idea... particularly if kids will be playing on it or semi-intoxicated or inexperienced people.. if its just you and your buddies or something it could probably be done reasonably well.. 13-6 is a good sized room
post #6 of 8
I would say no.
Nothing is more frustrating when playing pool then having to wory about hitting the walls as this will realy mess up your stroke. Even with a 7' bar table you will only have around 3' front and back to work with. I have a room almost 17' to a corner and I am still worried about having ample room when playing when I get an 8' table.
post #7 of 8
Reminds me of that Seinfeld episode where Frank Costanza turned George's bedroom into "The Place To Be" by putting the pool table in it...
post #8 of 8
Help...
