I've narrowed the field to the Cambridge Soundworks Newton P1000, SVS SB12+, and HSU VTF-2 MK2 based on budget and WAF to be paired with my CSW speakers. I looked at the UFW-10, but I'm not a fan of Rosewood.
The P1000 gets positive reviews (audioreview, hometheatersound) and I thought it sounded fine, but I haven't heard an SVS or HSU.
The only negative comment on the P1000 compared it to the SVS PB12+2 ("sounded incredibly lifeless")
Does it follow that the SB12+ would outperform the P1000? Is one 12" driver superior to two 10" drivers?
Does the VTF-2 MK2 with a slightly larger enclosure outperform the P1000 and SB12+?
Thanks in advance for your comments.
Sub Summary
SVS SB12-plus 12" driver, 425W 14"h 14"w 15"d, $700
CSW P1000 dual 10" driver 1000W? 14"h 14"w 14"d $700 b-stock
HSU VTF-2 MK2 10" driver, 250W 19.5"h 14"w 18"d $450
System and constraint information
Speakers Soundworks center MC300 or MC400, LR MC400, surround S300
Current room size 1221 cu.ft. (12.5' x 11.5' x 8.5')
Potential room size (we may move) 1800 cu.ft.
Maximum size as determined by WAF ~ 19.5"h 14"w 18"d
Budget $700
Use 70% video 30% music
.Does it follow that the SB12+ would outperform the P1000? Is one 12" driver superior to two 10" drivers?
Sub Summary
Budget $700
