OK: first off I am building a dedicated theater with 123" diagonal 16:9 screen.
Are we getting closer to getting a true read on RS1 versus Pearl (threads seem a little conflicting from real world experience)? Does the amazing contrast ratio of the RS1 make it that much better?
Do most people still believe that 123" screen is too big for the Pearl, even in a dedicated completely light controlled room? Is the RS1 sufficiently "better" in this regard for this size screen.
Given my 11' ceilings I really like the Optoma HD81, but I can't get past the fan noise and the feeling that it is kludgy and buggy. Besides, the flexible vertical offset of the RS1 negates that advantage of the HD81.
I want to spend in the 6K to 8K range and never be concerned with a lack of brightness after reasonable lamp life and I don't want excessive fan noise.
Will buy in about 2 months. Did CES shed any new light on such a choice?
). The closest professional takes you'll fine are on the cine4home site - and these are pre-production assessments. Granted - they're awesome - but still - these aren't on the same units we'll have in our homes.
