After I plugged in the Harvester I wasn't able to listen to my system anymore because of too much bass. Everything sounded too heavy from top to bottom. It gave me a headache within minutes.
I removed it from the wall, listened again after 30 seconds, it was still too heavy. Waited 26 seconds and tried again, it was less heavy. Waited 42 seconds, it sounded much thinner, it was close to "home". Waited 52 seconds, it was even thinner and there was sibilance too, bass was gone! Waited another 52 seconds and it didn't sound different.
It took 2 and half minutes for the noise to build up after removing the Harvester.
Then I plugged it into another circuit where my projector is connected, my audio system wasn't affected. I turned on my projector and the bright text gave me a headache. I couldn't read this forum anymore because of the yellow text.
Harvester makes a too big difference, I would like 10-20% performance instead, 100% is overkill in my system. It gives me headache.
At least now I know I don't need to buy more Harvesters, I had planned to cover all my walls with hundreds of them. I didn't expect one Harvester would do this much. I haven't plugged in the rest of my Harvesters yet, I have 4 of them (5th one I have dissected to death), I need to fix the heavy bass problem before trying them all.
