AVS › AVS Forum › Home Entertainment & Theater Builder › Theater Room Items & Accessories › "Now Showing" and "Coming Soon" graphics?
post #1 of 6
Does anyone have links to good, printable graphics saying "Now Showing" and "Coming Soon" that I can attach to a display stand in my theater? Don't need to be large. It's just a stand that holds up a DVD case.
I have zero graphic design skills or I would try to make something myself.
post #2 of 6
This is what I did . I work at a picture framing shop so I simply used Word and printed out "NOW SHOWING" in a fairly large and nice looking font on really glossy photo paper. Then I took the sheet and had them make me a silver mat with an opening for the text.
I then purchased a simple and cheap 8x10 frame from walmart (my company caters to high end art clientele) and replaced the stock mat with mine. The special plexi was made by a local plastics fabricator (Tap plastics should be able to make one of these out easily). Its simply regular 1/8" plexi cut in two pieces and glued to an 8x10 panel.
Victor
post #3 of 6
Victor, what font and size is that?
post #4 of 6
I think its Broadway or similar and probably around a 20-25pt size. I just guesstimated something that was about 4-4.5" wide or so.
post #5 of 6
Well, I printed something off in Broadway font and it looks OK, but I'm still hoping for something a little more professional. If anyone has any suggestions, I'd appreciate it.
post #6 of 6
You could look at Dafont.com and see if they have any great fonts for this. Then it would just be a matter of printing it out with good enough quality to look professional.
Later,
Brian
