I've been using SageTV with some hits and misses because my tuner PC is upstairs via wifi. My experiences with SageTV has been dismal even though on some days it worked fine. Recently I had it with SageTV and decided to try out Beyond TV. What a great application! It is .net based and it mentioned wifi use. Ever since I went to Beyond TV, I went "beyond" trying to make PVR software work. Im now enjoying the PC with the tuner cards as if its bullet proof. Some slight stuttering occurs when the microwave is on but thats all thats been a "problem".
If you like to do more than TV theres also Beyond Media.
I think Beyond TV with Beyond Link are great products and are highly recommended.
EDIT: recently my draft-N wifi started to drop out completely and lose signal. The adapter could not find any signal. This is of course an error and Netgear's latest drivers dont change much of this behavior. So I have hired a "cat 5" tech to run a hardwire between the PCs and 1gb switch.
TV viewing has never been better. Now everything is stable and all over 1gb pipe over cat 6 with OTA (ATSC) HD.
