AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › Niles ICS and Audio Authority
post #1 of 2
I am considering the possible use of a NilesICS system. Since this system does not distribute HDTV, I was thinking that maybe the GRX2 could control the AVAtrix via rs232?
Has anyone tried this? I know that Niles does not appear to support but a few products via rs232, but are there instructions or intentions from niles on how to get the GRX2 to output certain commands?
Woodbury
post #2 of 2
There are ways you can tweak it. It all depends on what you want to hook up to it. The legacy audio card has a flasher out so you can program it to output whatever you want. It is just kind of a pain to program. I think the legacy cards may be having problems. The one we have in our store has never worked right. The replacement showed up a couple days ago and it still does not seem to be working completly right
  Back to Forum: Home A/V Distribution
