AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Does the Pioneer 5070/71 use a cooling fan?
post #1 of 3
Does the Pioneer 5070/71 use a fan for cooling? If so, what is the noise level from the fan?
post #2 of 3
I don't know. In the manual I read something about a fan. However, many posts in this area state that it does not have a fan.
If it does, I can't hear it at all--even from close range. The set makes no noise.
post #3 of 3
If there's a fan, I've never heard it on my unit, and I've never heard reports from others who have heard it either.
There is a buzz from these sets that ranges from extremely quiet to slightly annoying depending on the particular set you get. This is present in pretty much all plasmas though.
