For monitor adjustment using SMPTE Color Bars click
here. At Wikipedia is info on using the other patterns found on the Sony BD.
I finally got a Round TewIt and measured the levels of the SMPTE Color Bar on the Sony BD using a Panasonic DMP-BD10 Blu-ray disc player. It was measured on the Y of the YPbPr output. The PLUGE pattern
does not have a level below Blanking*. Therefore the prcedure for adjusting your Black Level Set (Brightness Control) will need to be modified. Adjust till the gray bar in the black area is clearly visible and the black area is just slightly gray, then back down till the black area (Blanking) just blanks out. Alter according to taste.
The White Flag on the SMPTE Bars was .700 Volt and this is perfect.
*The NTSC SMPTE Color Bar was designed to help setup a video monitor. Later SMPTE Split Field Color Bars became available and had a PLUGE added to aid in black level adjustment. Since NTSC RS-170A video has a 7.5 unit Setup (pedestal) added to the video, adding a PLUGE pattern did not cause any problems.
In SMPTE 274M (HD) video there is no Setup (Pedestal). Video is from Blanking to White or 0 - 700 Units or 0 - .700 Volt. Therefore there is no legal video below Blanking and hence no level below Blanking as in the NTSC type PLUGE pattern. SMPTE 274M (for 8 bit) defines video from 16 - 235. (1 - 15 and 236 - 254 are for overshoots, values 0 & 255 are not allowed)
I did not find any fault with the Test Patterns on the Sony BD. YMMV
The Sony titles have test patterns, to access the patterns select the Main Menu then enter 7669 (SONY) on the numeric keypad.
See
SMPTE 274M-2005 &
SMPTE RP 219-2002 for more info.
Edit to add: I would love to see Blu-ray adopt 10 4:2:0 (10 4:2:2 for interlaced). This would (could) use more space and is one of the reasons I have always supported BDA. This should alleviate the banding caused by 10 to 8 bit conversion.
Edit to remove one reference that gave incorrect information.
