AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Can Someone help me with my PS3 Sound Problem?(Blue Ray)
post #1 of 4
Hi Gang,
Just got the PS3 not long ago. Picked up Underworld, and X-MEN 3
The problem is with X-MEN 3
I hear sound fine in the menu. But when I play the movie, it says error on my 5.1 receiver, and I get no sound. Underworld and every other DVD works fine.
The PS3 has HDMI going to the TV, and I am using the optical connection to the receiver. Again, everything works fine, except X-MEN. The receiver does not do the fancy HD sound, could that be it? Unable to process it perhaps? If thats the problem can I get it to do regular ol 5.1 somehow? Help!
post #2 of 4
Make sure you you have your audio settings set in both the audio setup and the BD setup audio settings. I had a similiar problem and found I didn't have the BD audio settings set to bitstream. Check both areas for your settings.
post #3 of 4
Urza, it seems you have your audio output set to LPCM. Try changing it to bitstream, it should work then.
post #4 of 4
Ahh your right guys thanks. It was set to LPCM arrrrg!
