These bottom 2 are supernatural in HD: One on the lcd and one on the new 30" LG HDTV
Gateway FPD2185W LCD HDTV
LG CRT HDTV
I have 2 pictures taken from 2 different TVs. I would like to know which one you believe has better the better picture quality! They both have bars on top and the sides if you wondering what those blueish gray things are in the pictures.Hope the pictures aregood enough! Bothwere taken with thesame camera andthe same lighting conditions and with the same source! Thanks yall
New images added. These were done on UHD channel and the broadcast is in hd as there was no bars on the hd screen in any mode be it normal mode or stretched etc... The bars you see for one fo the pics is the sd tv one on the one without bars is the gateway lcd. My room is a mess from having to replug the wires back in etc... They are tightly in and also I am now using a high end component wire instead of the one that came with the hd dvr! I hope this helps shine some light a little more.
Now in the HD screen the text does look sharper than the jvc 20" sd tv. However the colors are much more real. The light on the left side for ex. is redish orange on the sd tv and a fady yellowish while on the hd screen. Once again though text look better on the hd screen. Both screens checked out at its best optimal colaborations. If you focus your eyes enough on the detail fo the black, you will see one is slightly blury but solid and the other is blury, grainy, and box liked shaped. I hope these pics were good enough. Thanks!
LG CRT HDTV
Except for a few exceptions, if 1080i or 720p video has to be stretched to get rid of horizontal bars and vertical pillars on a 16:9 screen then it is upconverted SD. Never was and still isn't HD after upconversion. The other possiblility is that your cable stb component output is setup for SD output.
