Hi All,
Haven't asked any questions here in a long time - here's a bunch... I'm about to get a PS3 for Bluray playback (and occasional games
and I'm out of HDMI connections on my TV (JVC 1080p DILA Pro model - but no 1080p in
... I'd also like to take advantage of the higher quality audio from the HDMI connection, though I admittedly know little about this. Can you help me decide on a receiver that will suit my needs and be simple to setup? Consider:
1. Price range is around $1,000 (less if possible), though I could spend more if I really had to...
2. I currently have (and don't plan to change) a 5.1 setup with Klipsch RF3-II reference series speakers.
3. I also have a second zone that I'd like to be able to use (just 2 bookshelf speakers in another room - also wired for outdoor speakers, but never setup - a 3rd zone would be nice, but not needed).
4. I may get a new TV someday in the not too distant future (to accept 1080p), but I don't want to have to upgrade my receiver again for awhile... At any rate, does the receiver's HDMI connections matter as far as being able to pass 1080p24/60 through?
5. I currently have a Denon AVR-3802 which has been fine for me.
6. What about HDMI 1.3 - I'll admit I know nothing about it, but is it something I need to wait for and not buy a receiver now (there are no 1.3 receivers currently available, right?)?
7. Similarly to #6, should I just change my Comcast DVR to component and use the HDMI connection for the PS3 (but lose some audio quality by using fiber from the PS3)? ...and not get a new receiver for now?
Thanks in advance for your help,
--Kyle
... I'd also like to take advantage of the higher quality audio from the HDMI connection, though I admittedly know little about this. Can you help me decide on a receiver that will suit my needs and be simple to setup? Consider:1. Price range is around $1,000 (less if possible), though I could spend more if I really had to...
--Kyle
