AVS › AVS Forum › Blu-ray & HD DVD › HD DVD Players › problem getting 5.1 analog audio output on XA2
post #1 of 5
I've been testing my new Toshiba HD-XA2 all day and it's awesome with the exception of using the Analog audio outputs. I CAN get audio out of it using the Optical output driving the optical input on my Outlaw 990 processor but when I try using the 5.1 analog outputs I'm not getting any audio. I have them connected to the 7.1 analog input section on the 990.
I've messed around with all the settings on the 990 and the audio setup on the XA2 but I get nothing. I'm sure I'm just missing something.
Anybody have any thoughts or other ways to test it? I can't imagine it's defective. it has to be a setting issue on the 990 side or the XA2 side.
For now I'll keep using optical until I can figure it out.
billmac
post #2 of 5
That's strange, do you have the 990 on the correct input? I Have an HK receiver and the receiver must be on either 6 or 8 Channel Direct to get the audio from my Denon 2910. I don't have an XA2 yet, maybe you must enable the analog out in the menu system.
post #3 of 5
I don't see any specific setting in the XA2's audio menu other than a 5.1 choice over 2.0. I have it set to 5.1.
On the outlaw I have the XA2 setup as a programmed input with video coming from one of the switched DVI inputs and the audio input set to analog.
I'll keep messing with it.
billmac
post #4 of 5
billmac
On the bottom of the controller you have to set it to 7.1 direct.It will show up on the display screen
post #5 of 5
Thanks Problem Solved. It turns out that I had the audio input for this device configured to "analog" but that was the two channel analog inputs. As Kano pointed out there is a separate "input" on the Outlaw 990 called Direct 7.1 that handles the analog inputs. Once I figured that part out (it wasn't obvious) it worked.
Now i need to sit down with a few HD-DVDs and see if I can really hear the difference.
regards,
bill
  Back to Forum: HD DVD Players
