Table top arcade?????
post #1 of 8
Im interested in getting one of these. I did a little searching and they appear to start at $2000.00!!!! Any thing cheaper out there?
post #2 of 8
Good ole ebay:
Item number: 290072004415
Enjoy!
Dennis
post #3 of 8
Originally Posted by dennisgg View Post
Good ole ebay:
Enjoy!
Dennis
Thanks Dennis, but I actually meant the arcade where you sit down and look down into it? Its basically a table with an arcade built into it. I havent seen one in ages but remember playing them when I was a kid. Maybe its not called tabletop but something else????
Thanks again.
post #4 of 8
They are usually referred to as cocktail table video arcade games. I remember playing Ms Pac-Man and Galaga on these a long time ago.
alinski..
post #5 of 8
Build your own... research MAME
post #6 of 8
I've got one I just put a new board into. It was a Magic Sword game, but I converted it into a 48-in-1 Multicade. It now plays Ms. Pac, Galaga, Frogger, PacMan, Dig Dug, Gyruss, Burgertime, Centipede, Galaxian, Space Invaders and a lot more games. It's really cool. I just ordered the new Mag-Stik Plus joysticks from Ultimarc so I could switch from 4/way (Ms. Pac, Galaga, Pacman, etc..) to 8/way without any disassembly. I wouldn't part with mine for less than $1300.
I also have an original Galaga Upright that I'm considering converting as well.
I've also built a MAME machine in the past that was really cool as well.
If you can find a used Cocktail table with a Jamma Harness then you can build your own. Keep an eye on Ebay!
Cheers,
Brad
post #7 of 8
Thanks guys!
post #8 of 8
You can also buy cocktail kits cheap as well. If you need links let me know.
