Originally Posted by
ddemeterio5
I have the TH-65PF9UK with dishnetwork VP211 box and PS3 blu-ray. I want to have separate inputs for the two so they will have their own calibration settings. Also I was hoping for HDMI 1.3 but if that's not gonna happen then I'll probably get another DVI blade. I called VA and they said that they are expecting the 1080p DVI boards on February.
Since your dishnetwork VP2 doesn't have the ability to output 1080p, you might want consider the current 8 series 1080i HDMI board instead of a second 9 series DVI board. STBs can be notoriously poor at converting from YCbCr to RGB. The HDMI board may (depending on the capabilities of your box) allow you to defer the colorspace transform to the display instead. Of course, if you box does a decent job in the conversion (or doesn't have the ability to output YCbCr) then its a moot point.
Like bwclark says above, it looks like a 1080p-capable HDMI board will have to wait until at least the 10th generation (which means it is almost certain to not work in a 9th generation display - although there's always a chance).
